Scaler tree model
  • November 14, 2018
  • 5 replies
  • 24 views
I have a problem and it looks fine until I add the scaler. I can´t get the result good with the scaler. I scaled the orginal model to the size of one meter, so the scale factor is right, e.g. a tree with the height 8 meters should have scale factor 8. Why inspector showing strange geometries when I add scale or z in the scale parameters?
IInspector_point.zip have this shapefile also
gio
Forum|alt.badge.img+15
  • November 14, 2018
@tobiasrydlinge1
Have you set it to scale from center? (scale Origin)
Can't load your fmw, get an error.
Seems to work for me..
mark2atsafe
Forum|alt.badge.img+45
  • November 14, 2018
What's your coordinate system? If it's lat/long you may have to set the scale in decimal degrees (or temporarily reproject to a coordinate system with metre units to scale in metres)
mark2atsafe
  • November 14, 2018
If you can attach the skp file too, then we can run the workspace for real.
Hi!
Thank for your input @gio, @Mark2AtSafe. I changed a few things in my script and now I get the model right. My final fme script looks like this.And the final result
