Text of AutoCAD block doesn't follow block definition
  • May 30, 2019
  • 6 views
zzupljanin
Forum|alt.badge.img+4
So, I've prepared template file with block definition. This particular one has circle and text in it.
In FME 2017 I'm defining text using fme_attrib_info instead of DWGStyler.
The only problem that occurs is that this text that is inside of block goes to default layer (0) and default color (white). It should be blue like the definition of block says it.
Kind Regards,
Zelimir
zzupljanin
  • May 30, 2019
It appears I'm wrong. This only looks like in FME Data Inspector. If you open file in AutoCAD, everything is as it should be.
Cheers.
