Splitting delimited addresses into attributes (exposing individual list elements)
I followed the esxample here to split my comma separated addresses .
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/attributesplitter.htm#
However this is not working
I exposed the elements of the AttributeSplitter
But they are not available in the AttributeSplitter output nor the AttributeManager
I also tried ListExploder but that gave me a multipe row of the address elements And I want the address parts in a single row in columns
What Am I missing here?
thanks
  • June 27, 2020
Don't worry, that's just an issue on the Table View in FME Data Inspector and the Visual Preview.
Click the Columns button to open the Table View Schema window. You can then check the list name to expose the elements.
ah thank you . This was my first time using 2020 .most of my workspaces are 2017!
