How to detect, in a file fgdb, the attributes which are a date to be able to modify their formatting?
  • February 14, 2018
  • 7 views
lavairye
Hello,
I created a workflow that takes several FGDBs into a directory and dynamically exports them as Geojson files with their jsonschema, and it works well. But ...
The result for attributes with a type "date" is something like "20180205152004" (which is, I suppose, the string in the FGDBs files)
What I want is a rfc3339 format like "2018-02-05T15:20:04".
As my files do not have the same structure, I would like to be able to detect any attribute of type "date", to modify it so that it respects the standard rfc3339.
Of course, if I could know what are the good attributes I could use the DateTimeConverter!
All my efforts remained vain.
Does anyone have an idea?
philippeb
Forum|alt.badge.img+20
  • February 14, 2018
Maybe AttributeValidator would be useful. If it fails, you use DateTimeConverter.
