Generic writer - set at runtime
Hi All,
Does anyone know how to set the FORMAT for a Generic Writer at run-time? I have a generic reader and want to output to whatever format the input data was. Is there a good way to do this?
I've tried getting the input fme_format_short_name and using that as an attribute, as well as OUT_FORMAT, OUTPUT, FORMAT, and OUTPUT_FORMAT. But all fail with the tautological:
ERROR |Generic Writer: Cannot use the Generic writer to create a Generic writer. Please select a different writer for the FORMAT keyword.
Thoughts? Thanks,
Jonathan
gio
Forum|alt.badge.img+15
  • February 18, 2015
This works.
Any help?
Greetzz.
  • February 18, 2015
I'm afraid not. I don't want to set it via a parameter because I don't want the user to have to set it. It'd be easy if I could do that. :-)
gio
  • February 18, 2015
I used tst as filename, but you can make this a parameter as well of course.
AttributeCreator becomes:
outformat =
$(DestDataset_GENERIC)$(FileOut).$(GENERIC_OUT_FORMAT_GENERIC)
  • February 18, 2015
I not think it is possible to set the Generic writer format at run-time. Your closest bet is using a published or private parameter (those are evaluated just before run-time).
David
  • February 18, 2015
Gio - Sorry, that's not what I want to do. What I want is to be able to set the output format itself.
David - Ok. It seems odd that it's not possible as it's a simple use-case.
Thanks
  • February 18, 2015
Hi Jonathan,
Just an idea.
If the input format could be determined by the file extention of specified source dataset, it might be possible to define a scripted parameter that returns appropriate output format name based on the input format.
Takashi
gio
  • February 18, 2015
Ah, i think you must read the extension into the $(GENERIC_OUT_FORMAT_GENERIC) using a script.
I think a start-up script would do.
I tried creating a tcl to do that in a scripted parameter, but run into "ParamFuncinvoked from within" error.
gio
  • February 18, 2015
yes i did try that Takashi, using tcl scripted parameter :
[string range $(SourceDataset_SHAPE) @Evaluate(@Evaluate([string length $(SourceDataset_SHAPE)])- 3) @Evaluate([string length $(SourceDataset_SHAPE)])]
to get the extention and then somehow pass it to set the "$(GENERIC_OUT_FORMAT_GENERIC)" parameter.
..but all attemtps ended in "ParamFuncinvoked from within" error.
Maybe a startUp script to set it?
  • February 19, 2015
Gio, a Scripted (Tcl) Parameter with this script returns the extension of the source dataset, for example.
return [lindex [split $FME_MacroValues(SourceDataset_GENERIC) {.}] end]
FME Functions such as @Evaluate don't work in a Tcl script.
And also, in FME 2015, the @Evaluate function will not evaluate Tcl script and string expressions no longer. The function is now only for evaluating a math expression.
gio
  • February 19, 2015
Actually in the Evaluates are to Evaluate the tcl functions. And they do work in for instance a creator or a tester. The tcl bit i posted works exactly as intneded when used in a creator &co. And it does return the extension.
This is not the problem though in the scripted parameter. The problem is it can't reach the parameter "$(SourceDataset_SHAPE)" : "ParamFuncinvoked from within" error
That is what Jonathan is trying to do. Set output filetype to same as inputfiletype.
( i think he has to either use a workspacerunner, or use extension to select one writer using a testfilter wich boils down to basicaly entering writers for all expected possibel filetypes.)
When fme2015 is rolled out here (next week or so; i accepted and tested the instalation) we will see if i can do away with the @Evaluate.  But if u use nested tcl bits, u need to use @Evaluate(). At least in and up to fme 2014sp2. Nesting is common practice.
This does not apply however to using tcl in script in a tcl caller; no need for the @Eval there.
So in a start-up i would not need to use the @Evaluate. This is only needed when used in the transformers.
(i do hope i can still use tcl in transformers though...if not that would be a big drawback)
  • February 19, 2015
My words were shortage.
The @Evaluate still evaluates Tcl script in FME 2015. But it will return <null> if the result was non-numeric. So you cannot perform any string operation through @Evaluate+Tcl.
Hi All,
is there a way to get the FORMAT from the generic reader and pass it to the generic writer automatically in newer versions of FME somehow?
jdh
Forum|alt.badge.img+28
  • August 21, 2018
Yes, if you have a generic reader and expose the fme_basename, fme_format_short_name and fme_basename, then use a FeatureWriter, in the Writer Parameters set the Output Format to fme_format_short_name and the Base filename to fme_basename (unless you want a different output file name, in which case set it to an attribute containing that name)
In the feature type parameters set the Feature Type Name to fme_feature_type, Geometry from Schema Definition, Check off Dynamic Schema, and set the Schema Sources to your generic reader.
If you would like a different Feature Type Name, then set that to whatever attribute contains the name, but the Schema Definition Name must be set to the fme_feature_type.
