I'm trying to convert an ASTM e57 file to LAS, and retain the e57 station IDs as the LAS Point Source ID attribute. Is there a way to do this? Thanks!
E57 to LAS with time and station ID
Best answer by trentatsafe
Hello @wolfsnipes
You should be able to write the E57 station IDs to the LAS Point Source ID component, aslong as the values are between 0-65535. It should be noted that with having the Station IDs as an attribute, you will need to use a PointCloudComponentAdder or similar transformer, to convert the attribute to a component.
I hope that helps.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
