How do I format attributes in the attribute manager?
I am just learning to use FME and have run into my first issue. I removed a value ({}) using the TrimRight and TrimLeft (
@TrimRight(@TrimLeft(@Value(GLOBALID),"{"),"}")
in the attribute manager but now I need to add those values back in so I can load the data into a database. This is what I did and no such luck.
@Format("{",@Value(SERVICELOCATIONGUID),"}") Any help would be welcomed.
  • June 2, 2016
Hi @natashalaw, you don't need to use any string function. Just concatenate {, the attribute value, and } in the field.
{@Value(SERVICELOCATIONGUID)}
  • June 2, 2016
Addition. Regarding trimming, you can also use the @Trim function.
@Trim(@Value(GLOBALID),{})
