Downloading FME Desktop 2013 SP3
On our server we use FME Server 2013 SP3 (Build 13528 - linux-x64). We also use FME Desktop to make our workbenches. A colleague told me that I need to use the same version of FME Desktop if I want the workbench to work without problems. So I think I need FME Desktop 2013 SP3. However, I cannot find this version on the FME Download site, and I read that I need to contact support. Is this the right version for me, and if so, where can I download the installer?
Thanks in advance!
Best answer by lau
Indeed it's safer to use the same version desktop/server.
I think every release can still be downloaded. You only need to know (or to build) the url:
Can you give a try on:
https://downloads.safe.com/fme/2013/fme-desktop-2013-SP3-linux-x64.run
Let me know
lau
Forum|alt.badge.img+3
  • August 8, 2018
Let me know
Forum|alt.badge.img+50
Let me know
In addition to what @lau said: this page goes back to FME 2015
Let me know
Thanks for your quick and helpful answer! :)
