csv to xls
  • October 15, 2013
  • 29 views
paula
Hello everybody,
how can I convert a csv-file into a xls-file? How can I declare the delimiter?
Thanx
  • October 15, 2013
the easiest is to use the "Generate workspace" functionality in FME Workbench (see under File -> New).
When creating the CSV writer, click the "Parameters..." button to get to the dialog where you can specify the delimiter, etc.
David
paula
  • October 15, 2013
Hi David,
csv is the reader and xls should be the writer.
paula
  • October 15, 2013
Hi David,
thank you for the delimiter hint.
After I added the columns for my excel-file as attributes it's working now.
