@dmitribagh when I try to put a .tiff into minecraft the I have negative z values and I cant scale it down any further.
FME says I need to scale it down however no matter how much I scale it the z value is always negative. I also have the exact same area as an excel file that I can use for converting. would this be any easier?
Be the first to reply!
