How to create from-to lines in star topology for ShortestPathFinder
Hello FME community,
assuming that I have to sets of points, one contains the center nodes of the star topology and the other contains the child nodes of each star, how could I create the from-to lines for the ShortestPathFinder?
All points of both sets (center nodes and child nodes) have got an attribute star_id which determines to which star they belong. For instance, star A has got one center node with star_id=A and 8 child nodes with star_id=8, star B has got one center node with star_id=B and 6 child nodes with star_id=B etc.
I have tried the custom FromToBuilder from the FME Store and set both Join attribute option to star_id, but it only works for the first pair of points (center and child) of each star.
Best regards and many thanks in advance!
Best answer by takashi
Hi @tkifuchs, I think this workflow does the trick.
  • October 16, 2016
BTW: The PointConnector transformer may also do the trick, but I do not know how I can sort the input from those two different sets/sources in the required way. In my case: center node A, first child A, center node A, second child A, etc.
  • October 16, 2016
  • October 16, 2016
Excellent! Thank you very much! It works.
