stringsearcher to feature
  • November 21, 2016
  • 45 views
I have a feature class, and one of the fields is "tag". In the tag there are different slices of information stuffed. I need to get the next part: "addr:street"=>"East 79th Street".
The first part "addr:street"=> is always the same, it is the second part that differents every time.
I tried to use the "StringSearcher", Search In: "tag", Regular Expression: "addr:street"=>"([a-zA-Z0-9]+)".
But I now get no matches at all.
Is there anyone who can help me?
  • November 21, 2016
Hi @remcohofs, I think the character class in the regex should contain the white space.
Alternatively, the AttributeSplitter (Delimiter or Format String: =>) might also be helpful in this case.
mark2atsafe
Forum|alt.badge.img+45
  • November 21, 2016
If it is ALWAYS the first part, then I would use the SubstringExtractor. Set the Start Index parameter to 17 (the first character after the third ") and the End Index to -2 (the character before the final ")
That will give you the East 79th Street part, without quotes around it. If you wanted the quotes, then use 16 and -1 instead.
It's more hard-coded than a regular expression, but if the first part is always the same this way is much quicker to set up.
