There should be a way to have a dialog box appear in the workspace to notify the user about the output of the transformer. There is the logger transformer, but the message supplied only appears in the translation log. It would be helpful if you could run the workflow and get feedback that could then lead to alternative workflows depending on the output
<strong>This post is closed to further activity.</strong><br />
It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br />
If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br />
