Running into issues using TempPathnameCreator > HTTPCaller > FeatureReader
  • February 5, 2025
  • 27 views
hodsen96
Hey all,
In my previous post It was suggested to use TempPathnameCreator to download these files and once processed, the location and file will be deleted, saving disk space. However, I am unable to view any data in the FeatureReader. In this instance, my FeatureReader has 905 records under the <Generic> Port, but when I view it via Feature Caching, it says “No Schema” for the attribute name and all the values are empty. However, If i click the Columns and hit “select all” it seems that I can actually see the tables, but I can’t seem to access the data with an attribute remover or the likes.
Do I need to expose some attribute within the Generic Port <Attributes to Expose>?
Any help will be appreciated! Thank you!
Best answer by hodsen96
Seems I’ve figured it out...Grab a AttributeExposer and set it to Import > Feature Cache. This will let you select all the columns you want which are related to the CSV….Sorry for wasting y’alls time...
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
hodsen96
  • February 5, 2025
