Unable to view SDO_GEORASTER in ESRI
  • Jun 8, 2015 1:01 PM UTC
  • 0 replies
  • 36 views
We have an architecture with FME ,ArcGIS and Oracle Sptial and have below issue.
I have imported SRTM DEM into Oracle 11g using FME.The block size is set to 128X128.I am able to view the data in QGIS,Tatuk and play with it using GDAl command line.Unable to view the same in ArcMap.
ArcCatalog shows me The raster and RDT tables.I get the error "The specified raster column does not exist", when try to drag and drop.
I have verified that my DBTUNE parameters are set SDO_GEORASTER.
Am I missing something?
