Problem Regex in Python
  • Jul 7, 2017 5:30 PM UTC
  • 80 views
danilo_fme
Forum|alt.badge.img+58
Hello FME User's,
I'm reading a Website ( http://www.rio.rj.gov.br/ ) and through the transformer PythonCaller using Regex to find a value from attribute _response_body.
When the Workspace was executed a error is happened like the information bellow:
Python Exception <UnicodeEncodeError>: 'ascii' codec can't encode character u'\\xd3' in position 315: ordinal not in range(128)
Attached my template file.
Thanks in Advance,
Danilo de Lima
Best answer by david_r
As a side note: If you struggle with those kind of errors in Python, consider switching to Python 3.x in FME, that tends to make it a lot easier.
  • Jul 7, 2017 10:24 PM UTC
Hi @danilo_inovacao, the response body is a utf-8 string, and utf-8 code set contains character codes which cannot be encoded to ascii code. It's the reason for the error. You should not encode the response body string.
And, although it's not a direct reason for the error, you are wrong on use of the re.compile method.. I therefore cannot understand what you intend to do with the re module.
See here to learn how to use the re module.
Python Documentation | 7.2. re — Regular expression operations
danilo_fme
  • Jul 9, 2017 9:26 PM UTC
Hi @takashi, thanks your help.
I believe that the method re.search is better to fin any words between two strings.
Thanks
  • Jul 10, 2017 7:22 AM UTC
