Missing FMEPCConfg.exe in installation folder
  • May 16, 2024 9:38 AM UTC
  • 109 views
greymedal
Forum|alt.badge.img+3
Hi, I am trying to use the ImportFromFME package in Revit Dynamo and need to generate an FME Connection String using the FME Connection String Generator Utility, but I can’t find the FMEPCConfg.exe in my installation folder. Is it saved somwhere else or do I need another FME program like FME Server to use it? I have FME Form 2023.2 installed.
The executable is supposed to be in this area, but it’s not there.
hkingsbury
Forum|alt.badge.img+73
  • May 16, 2024 11:57 PM UTC
Looking through this article, it does say its been updated in the last 24 days, but noticing that it is tagged as being for 2018.x
https://support.safe.com/hc/en-us/articles/25407670868109-Integrating-FME-into-Dynamo-for-Revit
Might be worth directly contacting support to see if that article is still relevant for more recent versions
greymedal
  • May 17, 2024 6:33 AM UTC
Yeah, thats the article I originally used to even notice that a Dynamo-FME integration is possible. Sadly it doesn’t say anything about prerequisites to use or those mentioned arent all, because I do fulfill them. I will wait a bit for answers here and if nobody knows, I will contact support.
