FTP Caller works in workbench, but when i publish to server, the job can not connect with ftp.
  • September 22, 2017
  • 7 replies
  • 23 views
Best answer by erik_jan
Sounds like a ports issue. Is the right port opened on the FME Server firewall?
Sorry, but I do not exactly what port that should be.
@andrewegriffin Can you attach the log from the FME Server execution?
@larry
FTPCaller(FTPFactory): HTTP/FTP transfer error: 'Server returned nothing (no headers, no data)'
stalknecht
Forum|alt.badge.img+19
Please provide more information like a workspace and log files. Did you try to run it in workbench on the same server and what are the results? Probably a firewall is blocking the communication.
erik_jan
Forum|alt.badge.img+18
stalknecht
FTP so I think 21 https://nl.wikipedia.org/wiki/File_Transfer_Protocol
stalknecht
Probably port 21 https://nl.wikipedia.org/wiki/File_Transfer_Protocol
  • September 25, 2017
Could very well also be a proxy issue
