Failed to download files from AutodeskDocsConnector
  • February 27, 2025
  • 44 views
rmpayaby
Forum|alt.badge.img+3
I have added an FME Web connector towards Autodesk Construction cloud and have managed to access folders from my project. The list request seems to work in the AutoDeskDocsConnector-transformer, but fails when I want to download a file from the folder.
I get the following error when translating:
I use an ordinary Creator to connect to the AutoDeskDocsConnector. Does anyone have any tips what I’m doing wrong?
Best answer by david_r
Weird, I’m using it quite a lot and haven’t had that issue. You could perhaps try to downgrade to a previous version to see if it makes a difference: https://hub.safe.com/publishers/safe/packages/autodesk-docs
If that doesn’t work, consider contacting Safe support.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • February 28, 2025
Have you checked if there’s an upgrade available for the AutodeskDocsConnector package?
Look under Tools / FME Options / FME Packages, then click “Check for updates”
rmpayaby
  • February 28, 2025
I did, but there wasn't any upgrades available. It is on version 1.1.5 and I'm using FME Form 2024.2.2
  • February 28, 2025
