Archived
Add prefix initiator to SQLExecutor.
Related products:Transformers
  • March 20, 2018
  • 36 views
nielsgerrits
Forum|alt.badge.img+67
When reading data with the FeatureReader I often merge attributes as this is a more efficient alternative for using the FeatureMerger afterwards.
In the FeatureReader you can choose for Prefix Initiator to prevent overwriting conflicting attributes. This is not added (yet) to the SQLExecutor. Would be nice addition.
Current workaround is to use a BulkAttributeRenamer before the SQLExecutor.
danielkroon
I would like to see that too. But, I also want the option to prefix all attributes created by the query. Not only the initiator attributes. Example "SELECT a,b,c FROM alphabet" resulting in following FME attributes with prefix: prefix_a, prefix_b, prefix_c
It would also be nice to have the ability to do a case change, as you can do in the BulkAttributeRenamer.
