Open
Output if there are no features to output
Related products:FME FormIntegrationsTransformers
_jacques_
  • _jacques_
    _jacques_
a.bradley
Participant
Could there be an option so that if no features make it to the FeatureWriter, there is still a way to know that the workspace has run but that there were no outputs?
I have found a workaround by generating a count_id from the transformer before the writer and another count_id directly from a creator. From the creator, the count will always = 1. From the transformer, the count varies depending on how many features pass through. These are input to a FeatureJoiner which joins on both count_id’s and if there is any output from the UnjoinedLeft port then this feeds an AttributeFileWriter to inform the user there was no output.
crutledge
Forum|alt.badge.img+33
  • May 12, 2025
Hi ​@a.bradley I think the summary will give you just that. A summary count (including a 0 count) of features written….i think.
PierreAtSafe
NewOpen
raghavendrans
Forum|alt.badge.img+14
I think the NoFeaturesTester tells whether any FME features passed through the transformer or not?
https://hub.safe.com/publishers/safe-lab/transformers/nofeaturestester
