Archived
FME Cloud, version upgrade (one click)
Related products:Integrations
rylanatsafe
siennaatsafe
+27
  • rylanatsafe
    rylanatsafe
  • gerhardatsafe
  • siennaatsafe
    siennaatsafe
  • redgeographics
  • takashi
  • virtualcitymatt
    virtualcitymatt
  • danilo_fme
    danilo_fme
  • erik_jan
    erik_jan
  • warrendev
    warrendev
  • tcrossman
    tcrossman
  • j.botterill
    j.botterill
  • gazza
    gazza
  • fgiron
    fgiron
  • dbaldacchino1
    dbaldacchino1
  • jelle
    jelle
  • kennyo
    kennyo
  • helmoet
    helmoet
  • tjpollard
  • jpsalva
    jpsalva
  • prmorrison
  • seblegrand
    seblegrand
  • jmoura
  • cjd111
    cjd111
  • 01011010
    01011010
  • aviveiros
    aviveiros
  • jeroen
    jeroen
  • tono
    tono
  • spatialcase
    spatialcase
  • jurgen
    jurgen
  • kweller
    kweller
  • susmar
    susmar
  • laurawatsafe
    laurawatsafe
01011010
The process to upgrade an instance is a small hassle currently, I GREAT improvement would be say a "one-click" option.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
helmoet
Forum|alt.badge.img+8
  • September 20, 2017
Not sure I found a quick document on upgrading Cloud instance...
helmoet
Might not be that clear however that version upgrade involves more than just the FME Server Software, so let it be a two-click action :-)
Here is documentation that I used: Migrating an FME Cloud instance
helmoet
By the way @aaronkoning if I restore an older build FME backup into a new Cloud instance, will the superuser credentials become the credentials in the backup? Or does ik keep the credentials supplied in the one-time-supplied file?
jeroen
Forum|alt.badge.img+15
  • June 5, 2019
An direct way to upgrade your FME server instance to a newer version would be game changer. Everything (IP, Subscription, alerts and stuff) would still work or be there and you only need some basic testing to see if it works instead of termination a whole instance.
spatialcase
  • March 15, 2021
At least a quick way to update the current release as point releases (bug fixes) as made available would be very useful
aviveiros
Participant
  • Participant
  • March 25, 2021
Totally agree with the 'one-click' option to upgrade FME Cloud. Unfortunately, I now need to migrate my FME Cloud instance after having upgraded to FME Desktop 2021 and getting the warning "To ensure best compatibility, an upgrade of FME Server is recommended" when trying to publish to my existing FME Cloud 2020 instance.
01011010
  • September 17, 2021
This should be job one!
j.botterill
Forum|alt.badge.img+40
  • June 22, 2023
@Test Test​  is this possible to maybe a few clicks in the Flow hosted consoleUpgrading_An_Instance_workflowhttps://docs.safe.com/fme-flow-hosted/FME-Flow-Hosted/Content/About_Instances/Upgrading-an-Instance.htm
