Open
Add Thematic Mapping Capability to Data Inspector
Related products:FME Form
eulniyy
  • eulniyy
    eulniyy
ev_robin
I would like to be able to use thematic mapping in Data Inspector so I can inspect the values of different columns in raw data before I run translations. That would help me to find what data is relevant to the raw data I receive from our clients and would help me to answer my own questions of how I am going to transform the data by looking at how it looks spatially. I'm typically looking at multiple columns and unknown values in raw data.
  • May 28, 2017
I know it's not the answer you're looking for, but I've had a lot of success using QGIS for this. It's open source, reads a lot of formats (unfortunately not ffs ;-) and is really fast.
ev_robin
Forum|alt.badge.img+11
  • June 1, 2017
Thanks for the suggestion. I think that's a great idea. I usually do thematic mapping in MapInfo. But using QGIS would take out the step of transformation for me which would make it quicker to look at raw data. I've used QGIS a little bit.
I'd like to do this in Inspector as well, because there are times when I've made some tweaks and I'm already looking at the data there. If Inspector had that capability, I wouldn't have to go back to my translation and make more tweaks. Also I wouldn't need to open another program. It's part laziness... erm... efficiency on my part. To me, it's the greatest weakness of Inspector.
fmelizard
Forum|alt.badge.img+18
  • June 26, 2017
To be clear, @bruttino, you'd like to select a few columns and then have us assign colors based on the unique values for those?
geomancer
Forum|alt.badge.img+48
  • September 22, 2020
This is a great idea. I think in most cases thematizing on one column would suffice.
ev_robin
  • June 17, 2024
@fmelizard thanks for your reply! Sorry, I did not realize my posts had some attention. Doing this based on one column would likely be fine. An expression would be handy, but I could make the expression with an attribute manager if needed too.
