writing MText to DWG with specific textsize
  • Jan 27, 2021 6:03 PM UTC
  • 5 replies
  • 166 views
gpt_geoinfo
Forum|alt.badge.img+3
Hi there,
I want to write MText (multiline text) to DWG. If there is only 1 line the textsize is correct. As soon as there are at least 2 lines, the textsize shrinks. How can I prevent this?
screenshotI attached a simple workspace (FME 2020, 64bit). My actual workspace transforms data from an oracle database to DWG.
Cheers,
Maria
PS: In 2013 the question was already asked, but without any answer.
gpt_geoinfo
  • Mar 23, 2021 9:49 AM UTC
no clues?
caracadrian
Forum|alt.badge.img+23
  • Mar 23, 2021 10:23 AM UTC
Use the DWGStyler transformerDWGStyler MText
gpt_geoinfo
  • Mar 23, 2021 12:59 PM UTC
That's what I did/do! I tried to modify the parameters in any variation. I even tried two DWG-writers (ACAD, REALDWG).
Here's a preview of my workbench:
screenshot_workbenchsame result...
gpt_geoinfo
  • Mar 29, 2021 1:42 PM UTC
Alright... what now works for me:
Setting the attribute autocad_mtext_text_height to the desired size. The DWGStlyer doesn't work for Multi-text. If it works for you (@caracadrian​ ) please send me a sample workspace!
So, thanks a lot for the hint! 🙏
caracadrian
  • Mar 29, 2021 6:27 PM UTC
It appears DWGStyler  doesn't create the autocad_mtext_text_height attribute, as it should.
I had some complex dynamic labeling settings and created autocad_mtext_text_height somewhere before DWGStyler and got the desired output but it is not created by default.
Maybe someone from Safe can comment on this or you can create an ideea suggestion Idea List (safe.com)
