What causes a workspace fmw to be saved in JSON format?
  • Sep 19, 2022 10:31 AM UTC
  • 5 replies
  • 266 views
chk1
Forum|alt.badge.img+7
While looking through a folder of workspaces with a text editor, I noticed that one workspace fmw file was not in the usual XML-like format. It was instead a JSON file with a leading header line:
# application/x-fme-json-workspace
The last build/saved metadata states "FME(R) 2020.0.2.1 (20200511 - Build 20238 - WIN64)" - however when I create a new workspace with this version, it is saved in the XML format. I tried a variety of FME Desktop versions from 2019 to the most recent 2022, none save to JSON, but all are able to open the JSON fmw.
This question is in part simply out of curiosity, and also because I have made a small Python script that iterates over a folder to gather some metadata that the WorkspaceReader does not publish (luckily the attributes I'm looking for are in the same "path" in both formats).
  • Sep 20, 2022 7:20 AM UTC
That's an interesting observation, I've never seen this myself. I just searched through some 1400 workspace files (going back 10+ years) and was not able to find any such JSON variants.
I suspect you'll have to contact Safe support for this one.
chk1
  • Sep 20, 2022 4:44 PM UTC
Today I found another format which roughly looks as follows:
FMW0001
# bunch of metadata here
<binary data here until end of file>
File is not encrypted, I can't tell if it's just compressed in some way.
JennaKAtSafe
Forum|alt.badge.img+9
Hi @chk1​, thank you for brining up this interesting observation. Here are some thoughts on the origin of this json workspace.
Webbench in FME Server converts xml workspaces to json for the gui. This is the only place where we suspect the json workspace originated from. This however should have only been a temporary file on FME Server, and your instance "escaped". Hope this can answer a part of this mystery.
  • Dec 5, 2024 9:05 AM UTC
FMW0001
Recently stumbled upon one of these. In our case, there was a password set on the workspace. Removing the password and saving the fmw reverted the file contents back to normal.
itsmatt
Forum|alt.badge.img+48
  • May 28, 2025 10:30 AM UTC
FMW0001
If you have any encrypted CustomTransofmers in the workspace which aren't linked then the file will be encrypted it seems.
