Translation returns "FATAL: Expression false" ???
  • Jun 9, 2021 9:18 AM UTC
  • 5 replies
  • 138 views
lifalin2016
Forum|alt.badge.img+41
Hi list.
In the curiosity department, I have a workspace, that seems to finish , but misses some data, adding a small FATAL error message "Expression: false":
2021-06-09 09_21_42-_202099029 Import RSF DanDas XML to LER 2.0 data model (H__user_GIS-teamet_FME WWhat triggers this ???
Best answer by lifalin2016
I'm closing this question, there seems to be no obvious explanations.
Forum|alt.badge.img+63
Do you have a SQL statement specified for after writing by any chance? Is the data actually being written?
lifalin2016
  • Jun 9, 2021 10:38 AM UTC
Yes, but wouldn't that run after all output has been written? In my case I should have 80K "ledning", but only gets 17K.
My SQL run after translation is fairly straight forward:
UPDATE [$(TARGET_SCHEMA)].[Afløbskomponent] SET [geometri] = [geometri].MakeValid() WHERE [geometri].STIsValid() = 0
UPDATE [$(TARGET_SCHEMA)].[Afløbsledning] SET [geometri] = [geometri].MakeValid() WHERE [geometri].STIsValid() = 0
lifalin2016
  • Jun 9, 2021 12:03 PM UTC
I did manage to get the correct output without encountering any errors, but I had to single-step the entire workspace !!
During my trials I encountered another peculiar error that I haven't seen before:
2021-06-09 12_25_25-Window
hkingsbury
Forum|alt.badge.img+73
  • Jun 10, 2021 1:42 AM UTC
I believe that second error relates to the feature caching not finding a cached feature. I wouldn't worry about that one too much...
lifalin2016
  • Jun 15, 2021 8:24 AM UTC
