Tester filter not working
Show first post
geomancer
Forum|alt.badge.img+50
  • July 27, 2023
Would it help to pass the results of the ChangeDetector to a StatisticsCalculator? Group by fme_db_operation, calculate the Total Count. Then you can see the number of INSERT and UNCHANGED (and DELETED) features, and proceed from there.
  • July 27, 2023
I did but no success
geomancer
  • July 27, 2023
Unchanged features have value '<Missing>' in fme_db_operation.
  • July 27, 2023
okay, what about when there is no insert and only unchanged? so when only unchanged then the script will not run only when insert or Insert and Unchanged
geomancer
  • July 27, 2023
Maybe you can do something with the NoFeaturesTester (from FME Hub).
  • July 27, 2023
again this unchanged will trigger every time and truncate the table and add values each time when workspace run
  • July 27, 2023
as you can see there is no insert value and now whenever this run its insert the values in database
Maybe I'm missing the point, but check your writer and make sure you're not dropping or truncating the table...
geomancer
  • July 27, 2023
Nowhere in this workspace do I truncate a database table or add values.
You wanted to know when there are only inserted featurers, or when there are only unchanged features, or when there is a combination of inserted features and unchanged features.
The four Junctions give you exactly that. Now you can add whatever logic you want after each of the four Junctions, or combinations of Junctions.
  • July 27, 2023
which workspce
geomancer
  • July 27, 2023
The image of a workspace in my above post.
  • July 27, 2023
can you share the workspce
geomancer
  • July 27, 2023
See the attached workspace.
I emulated the table data and the update in two Creators. You can change the values in the creator by right-clicking Data, choosing Edit Attribute, and editing Value.
