Tester filter not working
  • Jul 20, 2023 12:52 PM UTC
  • 38 replies
  • 279 views
Show first post
geomancer
Forum|alt.badge.img+71
  • Jul 27, 2023 6:43 AM UTC
Would it help to pass the results of the ChangeDetector to a StatisticsCalculator? Group by fme_db_operation, calculate the Total Count. Then you can see the number of INSERT and UNCHANGED (and DELETED) features, and proceed from there.
asadamjad
Participant
Forum|alt.badge.img+12
  • Participant
  • Jul 27, 2023 6:52 AM UTC
I did but no success
geomancer
  • Jul 27, 2023 8:50 AM UTC
Unchanged features have value '<Missing>' in fme_db_operation.
asadamjad
Participant
  • Participant
  • Jul 27, 2023 8:53 AM UTC
okay, what about when there is no insert and only unchanged? so when only unchanged then the script will not run only when insert or Insert and Unchanged
geomancer
  • Jul 27, 2023 11:38 AM UTC
Maybe you can do something with the NoFeaturesTester (from FME Hub).
asadamjad
Participant
  • Participant
  • Jul 27, 2023 11:40 AM UTC
again this unchanged will trigger every time and truncate the table and add values each time when workspace run
asadamjad
Participant
  • Participant
  • Jul 27, 2023 11:42 AM UTC
as you can see there is no insert value and now whenever this run its insert the values in database
Forum|alt.badge.img+63
Maybe I'm missing the point, but check your writer and make sure you're not dropping or truncating the table...
geomancer
  • Jul 27, 2023 2:15 PM UTC
Nowhere in this workspace do I truncate a database table or add values.
You wanted to know when there are only inserted featurers, or when there are only unchanged features, or when there is a combination of inserted features and unchanged features.
The four Junctions give you exactly that. Now you can add whatever logic you want after each of the four Junctions, or combinations of Junctions.
asadamjad
Participant
  • Participant
  • Jul 27, 2023 2:16 PM UTC
which workspce
geomancer
  • Jul 27, 2023 2:17 PM UTC
The image of a workspace in my above post.
asadamjad
Participant
  • Participant
  • Jul 27, 2023 2:18 PM UTC
can you share the workspce
geomancer
  • Jul 27, 2023 2:36 PM UTC
See the attached workspace.
I emulated the table data and the update in two Creators. You can change the values in the creator by right-clicking Data, choosing Edit Attribute, and editing Value.
