SharePointOnlineConnector Document Set
  • Sep 17, 2020 3:12 PM UTC
  • 95 views
Forum|alt.badge.img+3
Is there any way to create Document Set using SharePointOnlineConnector ?
chrisatsafe
Hi @ukrsolid​,
Currently the SharePointOnlineConnector can only be used to manage files on SharePoint Online by uploading, downloading, deleting files, and deleting folders.
If you want to create a document set, you'll need to use the SharePoint REST API. You might be able to do get this done with the HTTPCaller by following the suggestions on these articles:
  1. Create document set with REST API in SharePoint Framework
  2. Creating a Document Set with the Sharepoint 2013 REST API
  • Sep 21, 2020 7:10 PM UTC
thanks @chrisatsafe​  ! I will check SharePoint REST APIs
