Running a BAT file on Desktop & on FME server
  • Dec 20, 2022 4:50 AM UTC
  • 318 views
kelvin.jenkins
Forum|alt.badge.img+5
Hi All,
I've been having a lot of issues trying to get code execution on FME server via System Callers. Been through every forum post about this without success.
I've attached a workspace that I'm using to create BAT files and run them with System Caller. SystemCaller 1 and 2 will run on desktop, but not on the server.
The server log shows:
Failed to Execute `"C:\\ProgramData\\Safe Software\\FME Server\\resources\\system\\temp\\engineresults\\b80d9262-f6b1-4c81-8f97-a505f68c95b2\\TauDEM_Run01.bat"'
Failed to Execute `"C:\\ProgramData\\Safe Software\\FME Server\\resources\\system\\temp\\engineresults\\b80d9262-f6b1-4c81-8f97-a505f68c95b2\\TauDEM_Run01.bat" abc'
SystemCaller 3 and 4 will fail on desktop and server.
At this point i'd be really keen for a workflow that Bypasses the System Caller. I'm really happy with the BAT file being created, but executing it on the FME server is proving way too hard.
Maybe a python script that can Call the BAT?
  • Dec 20, 2022 8:21 AM UTC
You can use a PythonCaller using e.g. subprocess.run() to execute a batch file.
https://docs.python.org/3/library/subprocess.html#subprocess.run
