Polygon generalize
  • Sep 10, 2020 5:46 PM UTC
  • 275 views
venu
Forum|alt.badge.img+5
The below shown image polygon is generated from 4 lines and the big vertical line's top and bottom portion of polygon should be smooth like shown below expected output.
Please can suggest the workflow to achieve the result.
Input
Input
Expected outputOutput
caracadrian
Forum|alt.badge.img+23
  • Sep 11, 2020 4:14 PM UTC
Use the Generalise transformer. Only problem is it will smooth the entire polygon, not just the "ends".
venu
  • Sep 11, 2020 5:56 PM UTC
Thanks for your response. I tried the result was not satisfied.
@Takashi Iijima​
Please can advise for to achieve.​
  • Sep 14, 2020 9:22 AM UTC
It might require a bit of work, but if you can extract the 3 end points on each end of this shape, which is easily done, you can use an arc estimator with these 3 points, or a 2DArcReplacer if you have more informations and want it a bit more precise.
And after you get the 2 arcs needed, you just assemble them with your output, as "Arcs and ellipses will be stroked prior to the calculation of the hull.", so not with the input.
If you know how to fill the blank/empty space, use the transformer, I don't know if there is one
If you don't, you can fill it with a custom transformer using python (might require multiple calls)
https://matplotlib.org/3.2.1/api/_as_gen/matplotlib.pyplot.fill_between.html
And finally use the dissolver to erase any interior leftovers
Sounds tortured, and it is, but it should work. There might be and easier way.
Hope this helps
