ListBuilder issue - any help appreciated
  • Nov 9, 2020 8:41 PM UTC
  • 144 views
sar_copp
Forum|alt.badge.img+5
UntitledI am creating a 'school catchment finder' so when a user types in their postcode, it brings up a list of schools catchments that their address resides within (i.e. essentially a point in polygon query). I want the result to bring up a table of 10 school types regardless of if that school type has a catchment at that address or not e.g.
Primary School
Junior School
Catholic Infants
Catholic Primary
Academy School etc.
The issue I have is when using ListBuilder, if one of the school types is not present at that address, the column headings still appear, but a different school type is listed under the school name. This sets the table information off kilter.
E.g. If a Catholic Primary school is not present, they Academy School information appears under the Catholic Primary school headings which is obviously incorrect.
From the images below, can anyone tell what I am not doing correctly?
Untitled2Untitled3
@sar_copp​  If you're comfortable with Python, then a short python script could probably do this easily. See the end of this article: Transformers for Working with List Attributes
Alternatively, try dropping the ListBuilder. Instead, add a TestFilter after your Listexploder and split the schools by type. Then either have a separate AttributeCreator for each school or try the BulkAttributeRenamer and add the school type as a prefix. Once all the schools have been renamed, you could bring them together with an Aggregator.
sar_copp
  • Nov 10, 2020 11:17 AM UTC
Thank you, I will have a look at all that!
