Is there a way to share workflow for others to make use of?
sameer
Forum|alt.badge.img+18
Hello there,
I'm referring to specific/general tasks that other FME users might undertake as part of their job.
For instance translation/transformation of Ordnance Survey Code-Point polygons/geocoding based on postcodes/extraction of address points data based on specific boundaries...
Could be used as a learning tool for newbies and other experienced users.
Is that feasible or maybe such site/forum does exist already and I've missed it?
Thanks,
Sameer
Best answer by david_r
You can share custom transformers and workspace templates on the FME Hub:
https://hub.safe.com
  • April 25, 2019
rahulsharma
Forum|alt.badge.img+10
Hi @sameer, as suggested by @david_r, its best practice to share your workflow with others. I would also like to add if you can document your workflow to try and explain steps(using bookmarks or annotations) that would be very helpful for other users.
sameer
  • April 26, 2019
@david_r: Thank you for getting back to me. I'll post my workflows on the Hub.
@rahulsharma: All my "live" workflows are documented as you described so hopefully should be okay for others to use.
Regards.
Sameer
