Is it possible to use multiple parameters as input for "Feature Types to Read" constraint of "FeatureReader" transformer?
  • Aug 22, 2022 7:44 PM UTC
  • 159 views
Recently started using FME (2020.2.3.0 now, but will switch soon to 2022) and was struggling with giving parameters as input for "Feature Types to Read" for "FeatureReader".
Input:
imageTGT_SCHEMA = "DATALAKE"
TGT_TABLE="GEODATA"
$(TGT_SCHEMA).$(TGT_TABLE) is given as input to "Feature Types to Read".
Expected behaviour:
I want FeatureReader to read the schema and table from parameters to become '"DATALAKE"."GEODATA"'.
Actual behaviour:
Snowflake Non-Spatial Reader: Error reading schema for table '$(TGT_SCHEMA).$(TGT_TABLE)'. Error: net.snowflake.client.jdbc.SnowflakeSQLException: SQL compilation error:
Schema 'DATALAKE."$(TGT_SCHEMA)"' does not exist or not authorized.
We are authorized and problem seems that FME can't parse TGT_SCHEMA correctly while it is defined. It can read $(TGT_TABLE) from parameters though?
Workaround:
Currently we have a workaround already to make variables from parameters with an "AttributeCreator" and then use @Value(tgt_schema).@Value(tgt_table) in "Feature Types to Read" constraint of the "FeatureReader".
Question:
We were wondering if we did something wrong with giving multiple parameters to "Feature Types to Read" or if this is a bug that can be fixed by FME?
@david_gis​ I couldn't reproduce this in FME 2022.1. In your error it does look like the TGT_SCHEMA is getting an extra set of quotes
so perhaps check that. But it does look like you have a workaround using attributes instead.
  • Aug 30, 2022 1:18 PM UTC
Thanks for the help Mark. Will try it later with FME 2022.1 too to see if I can reproduce it. For now we keep using workaround.
