invalid geometry type
  • Oct 14, 2020 3:09 PM UTC
  • 5 replies
  • 1248 views
gisbradokla
Forum|alt.badge.img+27
I am getting a rejection of one line in my wb that seems to be valid.
as per safe documentation i have place a geometry validator and geometrycoercer into the workflow. yet it is still rejected
Why would this be getting rejected for invalid geometry type?
geocoercer
with these parameters on the validator.
validatorparameters
Feature Type MValue_OUTPUT
Coordinate System NM83-EF
Dimension 3D
Number of Vertices 2
Min Extents 7764.78954863, 4086.494, 3384.991
Max Extents 7764.868, 4086.956395047, 3385.0004943987096
Attributes (61)
  _elevation 3384.991
  Alignment_Sheet_Status COMPLETE
  autocad_color 12
  autocad_entity autocad_line
  autocad_entity_visibility visible
  autocad_layer_desc
  autocad_layer_frozen no
  autocad_layer_hidden no
  autocad_layer_locked no
  autocad_layer_on yes
  autocad_layer_plottable yes
  autocad_linetype ByLayer
  autocad_linetype_scale 1
  autocad_lineweight -1
  autocad_original_color ByLayer
  autocad_original_entity_type autocad_3dPolyline
  autocad_resolved_linetype CONTINUOUS
  autocad_source_filename S:\\SURVEY\\AN\\GREEN_RAKE\\ASBUILT\\WORKING\\GREEN_RAKE.dwg
  autocad_space model_space
  autocad_thickness 0
  autocad_ucs_applied No
  autocad_ucs_origin_x 0
  autocad_ucs_origin_y 0
  autocad_ucs_origin_z 0
  autocad_ucs_xdir_x 1
  autocad_ucs_xdir_y 0
  autocad_ucs_xdir_z 0
  autocad_ucs_ydir_x 0
  autocad_ucs_ydir_y 1
  autocad_ucs_ydir_z 0
  autocad_vertexflag 0,0
  BEGIN_MEAS
  CL_Status
  Description SITE PIPE
  Diameter 6
  END_MEAS
  fme_basename GREEN_RAKE
  fme_color 0.65,0,0
  fme_dataset S:\\SURVEY\\AN\\GREEN_RAKE\\ASBUILT\\WORKING\\GREEN_RAKE.dwg
  fme_feature_type AB_PIPE_3D
  fme_geometry fme_line
  fme_type fme_line
  HYPERLINK
  In_Service_Date
  Layer
  LINE_ID 2
  M_Length
  multi_reader_full_id 0
  multi_reader_id 0
  multi_reader_keyword REALDWG_1
  multi_reader_type REALDWG
  Phase AB
  PipeType
  Route_Id 7CE7
  Source Brancher 0.BranchingFactory.Count 1
  Source Feature Router.BranchingFactory.Count 1
  State
  STATUS
  System AB_GREEN_RAKE
IFMELine (2 Coordinates) (776419.868, 408660.494, 3384.991), (776419.7895486304, 408660.956395047, 3385.0004943987096)
  Closed No
  Measures (1) <default_measure>
  Coordinates (2) Coordinate Dimension: 3
    0 7764.868, 4086.494, 3384.991 <0>
    1 7764.7895486304, 4086.956395047, 3385.0004943987096 <0.46900298176280636>
Forum|alt.badge.img+54
  • Oct 14, 2020 4:08 PM UTC
What transformer is MValue?
gisbradokla
  • Oct 14, 2020 4:56 PM UTC
measuregeneratormeasuregenerator
itsmatt
Forum|alt.badge.img+48
  • Oct 14, 2020 7:07 PM UTC
From the looks of the feature you've shared it's from the Output port rather than the Rejected port.​ are you able to share the summary of the rejected feature?
caracadrian
Forum|alt.badge.img+23
  • Oct 15, 2020 4:42 AM UTC
Inspect the Rejected port of your MValue transformer and check the Rejection Code.
That always tells you the reason. Probably Invalid Geometry Type in your case. My guess as an Autocad user is that you have a 0 length polyline.
  • Oct 15, 2020 8:42 AM UTC
My guess would be a path/multi part geometry. This would pass the GeometryValidation tests but be rejected by the measure generator
The MeasureGenerator doesn't actually complain about a 0 length line
