I am creating 3d model, there i want to apply textures to trees and electrical poles for improving there real time visualisation in 3d how to do that, I have the data in point shape file format representing the location for both the trees and electri
  • Jul 6, 2023 9:28 AM UTC
  • 85 views
two seperate shape file are there for trees and poles respectively, how to create there 3d visualisation with appropriate texturing.
itsmatt
Forum|alt.badge.img+48
  • Jul 6, 2023 10:02 AM UTC
This article should help you get started
https://community.safe.com/s/article/creating-and-using-geometry-instances
There is also this example FME Template which creates CityGML trees from points: https://hub.safe.com/publishers/con-terra/templates/citygml-create-solitaryvegetationobject-with-implicit-representation
They essentially use the same technique.
Thank you for the response.
I am trying this to run, here they are trying to implement model prepared on single entity on the set of entities, but I have image of the electric pole and I want to use it for visualization on rest of entities, in that sense what will be process flow, usage of feature merger transformer.
