How to find line segments which has different name?
I have a network file which has 100KMs of road(line) segments. When I dissolve it based on name I find there are so many small segments in between which has different name. e.g. Asian Highway is of 100 KMs but after dissolve I get 90Kms Asian Highway & remaining 10 KMs(Not continuous) in between has different name(e.g. ABD Road, xyz Street etc) how to find these segments only?
Forum|alt.badge.img+50
You could try running it through a SpatialRelator, if a line segment only touches 2 others which have the same name (but different from that line segment) it's likely that that is the kind of case you're trying to track.
I have used line combiner + ListExploder + Matcher which gives me output where name changes at any end but I want output where names are different at both end,
