How to filter this words?
  • Sep 23, 2022 12:31 PM UTC
  • 63 views
mr_fme
Forum|alt.badge.img+9
I have one column with this values.
I would like to filter only words that contais ABC letters.
But can´t be JACABC or RDABC. Sometimes the ABC is stay in second or third word after the comma, like image below:
CAP
Thank´s
Best answer by ebygomm
A string searcher with the following Regex should pass any features where ABC is the start of a string of characters at any point in the string, i.e. will match ABC123 but not JACABC123
\bABC\w+
\b is the word boundary
ABC are the characters ABC
\w+ is any number of word characters following (letter, number, underscore)
If you then need the actual matches themselves they are stored in the allmatches list which you can then explode, e.g. the last line in your example would match and return ABC6003 & ABC4
caracadrian
Forum|alt.badge.img+23
  • Sep 23, 2022 12:50 PM UTC
Use StringReplacer to replace space with nothing AttributeSplitter to split by comma (,), then Tester with Begins with ABC.
I think you need a ListExploder someware.
Forum|alt.badge.img+54
  • Sep 23, 2022 2:00 PM UTC
\bABC\w+
mr_fme
  • Sep 23, 2022 3:03 PM UTC
\bABC\w+
Thank you very much!
