Dissolve polygons
  • Sep 27, 2022 3:11 PM UTC
  • 5 replies
  • 73 views
dxirgu
Forum|alt.badge.img+4
Hello,
I need to do a simple operation in any GIS software, like QGIS, but I can't replay it in FME, and then load this data on ArcGIS Server.
For example, I have two polygons with the same code (two rown in a data base) and I need to fusion them into a single one, using a common attribute, the code. The result would be two geometries and only one row into database.
If I use Aggregator transformer, checking group by this attribute, apparently the result is ok, but output a geometry collection don't load to ArcGIS Server. I tried to use GeometryCoercer, after the output port of Aggregator transformer, but it didn't work.
So, can someone help me?
Thanks!
danilo_fme
Forum|alt.badge.img+58
  • Sep 27, 2022 4:19 PM UTC
Hi @dxirgu​
Did you try to use the transformer Dissolver?
dxirgu
  • Sep 27, 2022 4:34 PM UTC
Hi @dxirgu​
Hi @danilo_fme,
Yes, I tried, but output got more polygons than input.
Maybe I configured in a wrong way.
danilo_fme
  • Sep 27, 2022 4:54 PM UTC
Hi @danilo_fme,
Inspector
dxirgu
  • Sep 28, 2022 6:11 AM UTC
Hi @danilo_fme,
thanks for your help, but it didn't work, with this config.
imageOutput features get more features than incomming. In the next image, the correct number of features is from output port of Aggregator transformer.
dxirgu
  • Oct 21, 2022 6:19 AM UTC
Finally, I found out a solution. I used GeometryRefiner transformer after Aggregator transformer, to solve my problem. This worked for me.
