Creating GPX files with elevation
  • Jan 8, 2021 7:02 PM UTC
  • 8 replies
  • 192 views
I would really appreciate some help with the process I am trying to write.
I have a shapefile of routes, I need to create a GPX file for each route. However what I am stuck on is why the 'elevation' tag in the GPX is blank and I need to fix this. I assume I can use PointOnRasterValueExtractor
with the Terrain50Raster which I have in a raster GRID file?
The routes will change so I need the process to be repeatable on a regular basis hence why I am trying to do it the 'correct' way.
Many thanks
danilo_fme
Forum|alt.badge.img+58
  • Jan 9, 2021 7:18 PM UTC
Hi @safesarahfme​
This transformer PointOnRasterValueExtractor generate a list of attribute _band{}.value .
Is empty this information?
Thanks in Advance,
Danilo
Yes, I have a GPX file with the elevation field blank (because it came from a shapefile with no z values).
I have used a GEOTIFF dataset in the 'PointsOnRasterValueExtractor' as well as the GPX file above.
I can get the process to create a new GPX but the elevation data isnt being populated and the attribute_Band{}.value. is empty. Its driving me a bit mad now and I am sure I am missing something simple!!
danilo_fme
  • Jan 16, 2021 5:49 PM UTC
Thanks your feedback.
Can you share the workspace or print?
Thanks,
Danilo​
helpHelp very gratefully received, I have made sure that both the GeoTIFF and the Shapefile that was used to creae the GPX are both in WGS84 (EPSG4326)
danilo_fme
  • Jan 16, 2021 8:18 PM UTC
Thanks your print. Please use the transformer ListExploder after the PointOnRasterValueExtractor for explode the list 0.
How do I connect that in?
listexploderplanlistexploder
danilo_fme
  • Jan 17, 2021 3:59 PM UTC
Nice. You can rename this attribute using AttributeManager.
Now please insert the transformer 3DForcer.
