Create raster from point cloud by components
  • September 16, 2020
  • 53 views
ceciliac
I want to create raster based on several LIDAR component  that came with a pointcloud. These are:
Component: Reflectance
Type = Int16
Scale = 0.01
Component: Deviation
Type = UInt16
I would like to create rasters based on these atributes.
I have tried PointCloudSpliter, PointCloudPropertyExtractor but without results.
Any advice?
virtualcitymatt
Forum|alt.badge.img+36
There is probably an easier way, but this should be simple enough.
Use a PointCloudComponentRenamer to set the component you want to turn into a raster into 'z'. Then use the NumericRasteriser. If you don't want any holes then you can use the DEMRasterGernerator instead to create an interpolated grid.​
