batch deployment
  • November 8, 2021
  • 48 views
jofl
I have a problem after updating FME to 2021.2.
I use a txt file to get the workbench in a batch depoyment.
But after i have updated FME to version 2021.2 i get a notification that the file not exist. (name of the file txt.txt) I have this problem in all my workbenches who are running in a batch deployment. I have this problem after updating my FME.
Logfile:
Processing C:Gladheidsbestrijding      xt.txt (1 of 1)
Translation FAILED with 1 error(s) and 0 warning(s) (0 feature(s) output)
Text File Reader: Source dataset 'C:Gladheidsbestrijding       xt.txt' does not exist
An error occurred during the batch file execution of C:/Users/EJANSE~1/AppData/Local/Temp/FME_1636366013186_13572. 1 translation failed. The following error message was raised:
#1 : Text File Reader: Source dataset 'C:Gladheidsbestrijding  xt.txt' does not exist
Program Terminating
Translation FAILED.
child process exited abnormally
FME encountered an error. Please contact http://www.safe.com/support
CTL File
#!/usr/bin/env fme
set workspacename {C:/Gladheidsbestrijding/Gladheidsbestrijding.fmw}
lappend destMacroList {DestDataset_SHAPEFILE_1}
lappend suffixList {}
lappend destDirList {C:/Gladheidsbestrijding/Gladheidsbestrijding/}
lappend destMacroList {DestDataset_SHAPEFILE_2}
lappend destMacroList {DestDataset_SHAPEFILE_3}
set recreateSourceTree "no"
set superBatchFileName [FME_TempFilename]
set superBatchFile [open $superBatchFileName "w"]
lappend sourceDatasets {C:/Gladheidsbestrijding/txt.txt}
Best answer by jofl
The soulution to this problem is:
Put a txt file in the workbench and run the [Batch Deploy]
Throw the txt file out of the workbech and open the .ctl file.
Delete the /.txt in the path [lappend sourceDatasets {C:/Eikenprocessierups/.txt}] and save the file.
Now you kan run the workbench without a error message 😀
jofl
  • November 8, 2021
