I would like to use the tesseract ocr TesseractCaller transformer in FME Cloud. How do I reference it
  • Mar 2, 2023 5:01 PM UTC
  • 333 views
oliver.morris
Forum|alt.badge.img+14
In other words what do I put in here, FME Cloud is a linux box so I dont think it will be an exe.
Many Thanks for the help in advance!
Screenshot 2023-03-02 165953
paalpedersen
Forum|alt.badge.img+8
  • Apr 18, 2023 8:26 AM UTC
FME Cloud (or FME flow hosted) runs on ubuntu, so you would have to install it on that machine. The command for installing tessaract on ubuntu is: sudo apt install tesseract-ocr
There are many caveats for installing this software in the cloud. firstly it installs natively on the processing pod, this machine is just a temporary machine, and does not support mutating installations over a longer period of time, since it can be swapped.
You have permantantly storage in your resource folder, if you were able to install it there I believe you should be able to run it safely. But then you must remember to call the full path of the binary since it not in any system directory.
