Writing data to Microsoft Azure SQL Database Non-Spatial
  • Apr 9, 2018 6:45 PM UTC
  • 51 views
Good afternoon,
I'm trying to write data to our companies Microsoft Azure SQL Database Non-Spatial database, but I keep getting an error saying
"Microsoft Azure SQL Database Non-Spatial Writer: Existing table for feature type `Roads' does not have attribute with name `id'. Cannot continue"
However, when I open up the Roads table inside the SQL database, I can see the field id. I've set the data type in the writer to match the SQL database type, and I still get the error.
David
  • Apr 10, 2018 7:04 AM UTC
What datatype is the "id" column? Are you sure it's "id" and not "ID"?
Rather than manually creating the FME writer definition, try importing the table from the Writers / Import feature types... menu.
