Writer
  • Aug 8, 2018 10:34 AM UTC
  • 7 replies
  • 81 views
maica
Forum|alt.badge.img+4
I must update a Oracle table. I use this parameters on the Writer:
Create Table: No
Truncate Existing Table:Yes
Writer Mode: INSERT
But the table is not updated. Can you help me?
Best answer by david_r
If you don't want the reader to consider the sheet name, use a single merged feature type when creating the reader:
If needed, you'll get the sheet name in "fme_feature_type".
  • Aug 8, 2018 10:49 AM UTC
How many features are arriving at the writer?
Can you post the log file here?
maica
  • Aug 8, 2018 10:53 AM UTC
I don't receive errors. The log said:
Total Features Read 1026820Features Written SummaryTotal Features Written 0Translation was SUCCESSFUL with 3 warning(s) (0 feature(s) output)
  • Aug 8, 2018 10:57 AM UTC
What are the 3 warnings?
  • Aug 8, 2018 11:01 AM UTC
What does the number on the connection to the writer say? Is there a number at all?
Just be aware that if no features hits the writer, the target table will not be truncated.
maica
  • Aug 8, 2018 2:07 PM UTC
I understood the problem...the sheet name of the excel reader changed.
Can I insert an option that don't consider the sheet name?
  • Aug 8, 2018 2:22 PM UTC
maica
  • Aug 9, 2018 10:19 AM UTC
Thanks for your help.
