What is the way to extract Osm pbf file to esri_file_geodatabase for a large dataset in FME ?
  • Nov 27, 2017 11:08 AM UTC
  • 229 views
I want to extract the osm pbf file to gdb for the writer output OSM highway_poly line feature with max speed and Surface.
Is there a way to extract the osm pbf file to file gdb?
thanks in advance.
Best answer by danilo_fme
Hi @yasinmelon1,
The FME is enable to read the format : OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF)
Have you tried to create a simple Workspace:
File -> New -> Generate Workspace:
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Nov 27, 2017 10:34 PM UTC
Hi @yasinmelon1,
Thanks,
Danilo
