Splitting up a GeoTiff to evaluate cells colors
  • Jun 16, 2016 1:52 PM UTC
  • 58 views
I need to evaluate the color of each individual cell of a geotiff. I splitted the geotiff into it's cells using the RasterTiler with CellSize 1,1 and it seems to work. I do now just need to access the color of each cell and to test for it. I tried to do it using the Tester, but it seems that it doesn't work.
  • Jun 16, 2016 1:56 PM UTC
Try the RasterCellCoercer, it will output the cell values in the FME list "_band{}.value". Here's an old (but still relevant) article about it: https://knowledge.safe.com/articles/1281/rastercellcoercer-making-points-from-rasters.html
Just be aware that the RasterCellCoercer tends to be rather slow for large rasters. If it's too slow, consider going the point cloud route using the PointCloudCoercer, although I'm not sure if it lets you access the individual cell values.
  • Jun 16, 2016 2:07 PM UTC
Hi , depending on how you need to split the raster, the RasterExpressionEvaluator could also be an option.
I've previously tried to find a solution, but I couldn't manage to access the color there as well. The "_band{}.value" made the clue. After that I had to normalize the value and to set the color of the polygons. That way I got polygons with the same color as before and managed to keep the geotiff representation.
Edit: If someone is interested in the way I've done it, below is the custom transformer I created as image.
