Remove outliers of point clouds to extract the roof height
  • Sep 23, 2016 9:04 AM UTC
  • 6 replies
  • 245 views
I have clipped point clouds of buildings and I would like to calculate the maximum height from these point clouds, but without chimneys and other small features. Is it possible to retrieve more detailed point cloud statistics which can be used for this? I am not looking for the median of average values of the point clouds, but really the maximum z-values of the roof constructions.
  • Sep 23, 2016 9:10 AM UTC
Hi @erikjh, the PointCloudStatisticsCalculator and PointCloudFilter might help you.
itay
Forum|alt.badge.img+19
  • Sep 23, 2016 9:13 AM UTC
Hi, I think you will probably need another dataset to help you filter out the points which are of the roof construction, otherwise some kind of selection within roof will be probably the way to go.
  • Sep 23, 2016 1:41 PM UTC
A workaround might be to sort the height values in your building and remove the top 2 - 5%. This will remove the chimneys but maybe not every small roof structure.
  • Sep 24, 2016 8:05 AM UTC
Thanks for the suggestions! I'm going to experiment with removing the top 2-5% of the points, so this may be possible.
  • Sep 25, 2016 11:47 AM UTC
I created this workspace a while ago, it elevates building polygons by a percentile (based on height points that fall with building polygons. It was designed specifically to filter out chimneys, aerials, etc. Setting the $Percentile parameter to 90 will remove the top 10% height values. Setting it to 50 will give an average.
Hope it's useful.
  • Jan 13, 2021 4:15 AM UTC
I know it is too old post, but kindly did you solve it , if so may you post upload the solution
many thanks
