Recognize "strikethrough" in cells
  • Oct 16, 2017 6:55 PM UTC
  • 107 views
I am merging an excel spreadsheet and an ArcGIS SDE feature class on a common field. Some of the entries in the spreadsheet have a "Strikethrough" effect--these entries should be ignored, however, FME is matching them anyway. How can I get it to ignore any entries with strikethrough?
Best answer by david_r
Since the strikethrough is just a visual effect (like underline and italics), I don't believe that's currently possible using FME.
  • Oct 17, 2017 6:51 AM UTC
cws
  • Jul 24, 2020 6:57 AM UTC
Has there been any change to this in newer releases of FME. I have a similar issue where I'd like to filter out the strike through values in excel sheets.
Forum|alt.badge.img+54
  • Jul 24, 2020 7:15 AM UTC
@cws If you read the excel file with formatting you can identify those cells which have the Strikethrough effect
Tick this box in the reader
You can then test the .formatting attributes for the word STRIKEOUT
cws
  • Jul 26, 2020 9:43 PM UTC
Thanks @ebygomm. Works perfectly.
