Python Exception: No module named parser
  • Nov 28, 2017 4:08 PM UTC
  • 297 views
All:
I have an issue with the following error on my Windows 2010 R2 Standard 64-bit server running FME Desktop version 2017.1.0.0 (20170731 - Build 17539 - WIN64).
When I have the same version of FME running on another PC, the workspace runs fine without a hitch.
I can't seem to figure out the problem. Please note, I do have FME 2013 on this same server but the PATH for the environment variables have the 2017 path established before the 2013 path.
Please Help!!! :)
Python Exception <ImportError>: No module named parser
Could not create Python Reader `GOOGLESHEETS'
A fatal error has occurred
Best answer by david_r
Have a look at this post, I suspect it's the same issue:
https://knowledge.safe.com/questions/44922/getting-the-error-python-exception-no-module-named.html
Basically, try deleting the following files
  • fme\\python\\js2py\\translators\\pyjsparser.pyc
  • fme\\python\\js2py\\translators\\pyjsparserdata.pyc
  • fme\\python\\js2py\\translators\\std_nodes.pyc
  • Nov 28, 2017 4:11 PM UTC
  • Dec 5, 2017 1:19 PM UTC
Thanks. That worked.
